[gdal-dev] RE: progressive rendering
Adam Nowacki nowak at xpam.de
Sat Aug 23 20:08:05 EDT 2008
Norman Barker wrote:
> I have created RFC 24 on
> http://trac.osgeo.org/gdal/wiki/rfc24_progressive_data_support
I'd suggest creating completely new interface for this.
Why is this better (imo):
- application decides when and how ofter the updates occur, minimal
threading issues
- clearly defined synchronization points: NextAsyncRasterIOMessage(),
LockBuffer(), UnlockBuffer()
- requests can be aborted with EndAsyncRasterIO();
class GDALAsyncRasterIOMessage {
   GDALAsyncRasterIO *asyncrasterio;
   void *userptr;
  // GARM_UPDATE, GARM_COMPLETE, GARM_ERROR, ...
   int what;
   int xoff, yoff;
   int xsize, ysize;
class GDALAsyncRasterIO {
// lock a whole buffer
   void LockBuffer();
// lock only a block
   void LockBuffer(int xbufoff, int ybufoff, int xbufsize, int ybufsize);
   void UnlockBuffer();
class GDALAsyncDataset : public GDALDataset {
   GDALAsyncRasterIO *AsyncRasterIO( /* same as RasterIO */ , void
*userptr);
   void EndAsyncRasterIO(GDALAsyncRasterIO *);
// if there are no new messages return NULL if wait is false or wait for
new message if wait is true
   GDALAsyncRasterIOMessage *NextAsyncRasterIOMessage(bool wait);
   void ReleaseAsyncRasterIOMessage(GDALAsyncRasterIOMessage *m);
//  How to use it
GDALDataset *ds = GDALOpen( /* ... */, GA_ReadOnly);
// start asynchronous raster io, can have multiple running at same time
GDALAsyncRasterIO *r = ds->AsyncRasterIO(GF_Read, xoff, yoff, xsize,
ysize, bufptr, bufxsize, bufysize, bufdatatype, 3, NULL, 0, 0, 0, userptr);
while (...) {
   GDALAsyncRasterIOMessage *m = ds->NextAsyncRasterIOMessage(true);
   if (m) {
     if (m->what == GARM_UPDATE) {
// lock the buffer so there will be no updates while we read from it
       m->asyncrasterio->LockBuffer( /* ... */ );
// display updated region
       m->asyncrasterio->UnlockBuffer();
     } else {
// handle completion, display error message, ...
     ds->ReleaseAsyncRasterIOMessage(m);
ds->EndAsyncRasterIO(r);
