[gdal-dev] Support for reading GDAL datasets in compressed archives(.gz and .zip)
Wed Aug 27 09:43:01 EDT 2008
Baumann, Konstantin wrote:
> Hi Even!
> That sounds cool. Is there also a function for retrieving all available
> files inside of a ZIP archive?
Kosta,
Programatically this can presumably be accomplished with VSIReadDir()
(aka CPLReadDir()).
char CPL_DLL **VSIReadDir( const char * );
The VSI filesystem operations should generally work on virtual
file systems, though in the case of the zip driver I presume all the
update operations (like VSIRename() or VSIUnlink()) are unimplemented.
Best regards,
