[gdal-dev] Support for reading GDAL datasets in compressed archives (.gz and .zip)
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Aug 27 09:58:54 EDT 2008
Rouault,
Nice job!
Even Rouault wrote:
> To read from a .gz file,
> gdalinfo /vsigzip/path/to/the/file.gz were path/to/the/file.gz is relative or
> absolute.
> The first time that a .gz file is read, a small .gz.properties file will be
> generated (if possible) to capture the uncompressed data size. This will make
> following opening of that dataset much faster.
Suggestion:
Would be interesting to bring the content of "file.gz" as subdatasets:
Subdatasets:
   SUBDATASET_1_NAME=/vsizip/myarchive.zip/subdir1/file1.tif
   SUBDATASET_1_DESC=GeoTiff,100x110x1
   SUBDATASET_2_NAME=/vsizip/myarchive.zip/subdir1/file2.tif
   SUBDATASET_2_DESC=GeoTiff,100x110x1
   SUBDATASET_3_NAME=/vsizip/myarchive.zip/subdir1/file3.tif
   SUBDATASET_3_DESC=GeoTiff,100x110x1
What do you think?
> Small syntaxic sugar : if the .zip file contains only one file located at its
> root, just mentionning "/vsizip/path/to/the/file.zip" will work.
The same would apply to subdatasets, I guess.
> The fact that this new capability is implemented as virtual file systems imply
> that it will only work for GDAL drivers supporting the "large file API". A
> list of such drivers is : PNG, JPEG, ILWIS, GTiff, GIF, JP2KAK, NITF, ADRG,
> DTED, SRTMHGT, BMP, LCP, HFA (Erdas Imagine), AAIGRID. Other drivers may work
> too (I just looked for those advertizing the GDAL_DCAP_VIRTUALIO capability)
That all we need? Nice!
Best regards,
Ivan
