[gdal-dev] RE: progressive rendering
Even Rouault even.rouault at mines-paris.org
Wed Aug 27 16:34:58 EDT 2008
Norman,
as I see you are currently editing your proposal and I've not yet made my
comments, here I go.
I would like that the dataset object to be added as the first argument of the
callback, and a void* user_data to be added as the last argument
So the call would be :
ds->RasterIO (GF_Read, xOff, yOff, xSize, ySize, NULL (1), bufXSize, bufYSize,
bufType, nBandCount, bandMap, nPixelSpace, nLineSpace, nBandSpace,
pfnProgressIO, pProgressUserData)
typedef (*GDALRasterIOProgressFunc) (GDALDatasetH hDS, int xOff, int yOff, int
xSize, int ySize, void * pBuf, int bufXSize, int bufYSize, GDALDataType
bufType, int nBandCount, int* bandMap, int nPixelSpace, int nLineSpace, int
nBandSpace, void* pProgressUserData)
I've a few questions so that your explanations and proposals are clear to my
mind.
- Is the extended version of the RasterIO() call still blocking as the current
version?
My understanding of the discussion is "yes", but I would like a yes/no
confirmation. If "no", then I don't understand at all how it can work.
- What happens if the user specifies a not NULL argument as the output buffer
( in (1) ) ? What happens if the user specifies GF_Write ?
It is probably an argument for a name change, something like
ProgressiveRasterIO.
- Is it guaranteed that the bufType, nBandCount, bandMap, nPixelSpace,
nLineSpace, nBandSpace specified by the caller will be the values passed to
the call back function ?
- Maybe it can make sense to add some way of cancelling the whole RasterIO
call by providing a callback, like the standard progress callback
(GDALProgressFunc in gdal.h) mechanism do ? Because the RasterIO() will spend
most of the time waiting for data. It could resume from time to time to call
that callback and see if the user still wants the request to be continued. It
would be nice if the mechanism could provide some percentage of the total
progress as it might be tedious for the user to compute that ? But that's
probably not easy to define if you first update the whole request area with a
low resolution, and then at higher resolutions.
- What happens if the user issues another call to RasterIO(), traditionnal
version and/or your extended version, in the pfnProgressIO callback ? Is it
forbidden, or does the answer depend of the underlying driver ?
Best regards
