[gdal-dev] Segmentation fault using gdal 1.4.4 and 1.5.2 on netcdf
Mateusz Loskot mateusz at loskot.net
Wed Aug 27 16:43:48 EDT 2008
Vishal Mehta wrote:
> Hello all,
> I continue to have 'segmentation fault' error using gdal-1.5.2 on
> Ubuntu 8.04 with netcdf files.
> I re-compiled gdal from source again, this time with Dylan
> Beaudette's gracious help (thanks Dylan!). I still got segmentation
> fault.
> Below are the last few lines of strace - hope that helps in
> identifying what the problem is...
Vishal,
It would be yet helpful if you could give exact command (assuming you
use GDAL utilities) or code snippet you use to open your file.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
