[gdal-dev] geotiff image problem
mchapman at fortifieddatacom.com mchapman at fortifieddatacom.com
Thu Aug 28 10:30:40 EDT 2008
Silvia,
In your project properties in vs under the "Link" tab you need to add the path to the file "gdal_i.lib".
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
From: "Silvia Marchesi" <silviamarchesi at gmail.com>
Date: Thu, 28 Aug 2008 16:30:25
To: <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] geotiff image problem
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
