[gdal-dev] Injecting Projection information in CreateCopy
Christiaan Janssen cjanssen at iavo-rs.com
Fri Aug 29 12:04:11 EDT 2008
My problem with this is that I'm not actually trying to reproject the data. The best example of what I'm doing is trying to create a GeoTIFF version of a standard TIFF (ie create a full raster copy but with GeoTIFF tags for the projection and transform embedded), at the same time not limiting myself to only outputting to a GeoTIFF format but other geospatially capable formats as well (ie NITF, Erdas Imagine, ...) some of which only support the CreateCopy function.
Christiaan
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: Friday, August 29, 2008 11:45 AM
To: Christiaan Janssen
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Injecting Projection information in CreateCopy
Christiaan Janssen wrote:
> Could someone tell me the best/easiest way to create a copy of a
> GDALDataset from one format to another and specifying a projection
> different than what is contained in the source GDALDataset.
Have you tried to follow this [1] tutorial, see GDALCreateGenImgProjTransformer
[1] http://gdal.org/warptut.html
Best regards,
Mateusz Loskot, http://mateusz.loskot.net Charter Member of OSGeo, http://osgeo.org
