[gdal-dev] Extending csharp binding for resampling
Tamas Szekeres szekerest at gmail.com
Fri Aug 29 18:42:00 EDT 2008
Marc,
Wouldn't it be sufficient to create a warped vrt dataset either by
opening the corresponding xml file or using the AutoCreateWarpedVRT
API?
Then you might want to use ReadRaster on that dataset so as to load
the stuff into an in-memory buffer.
Currently there's no native way to access the warp operations from the
SWIG interface.
Best regards,
Tamas
2008/8/29 Marc Jacquin <marc.jacquin at magellium.fr>:
> Hi Gdal folks,
> Let's say we would like to use GDAL warping capabilities for resampling a
> dataset (without saving it on a file) at specific xcell and ycell with a
> specific resampling method but in Csharp. What would be the best way to do
> it?
> Let me guess:
> - First maintain our own Gdal build (that's fine)
> - Add the corresponding swig code to some .i files in the swig include
> directory
> - recompile the whole swig csharp stuff
> OK, but I'm not familiar with swig. Has anybody some swig code similar on
> the shelf? Wouldn't it be something useful to add to the official Gdal
> release?
> Regards,
> Marc Jacquin
> +(33) 562 247 023
> Magellium
> 24, rue Hermès
> BP 12113
> 31521 RAMONVILLE Saint-Agne cedex
> France
> Phone: +(33) 562 247 000
> Fax: +(33) 562 247 001
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
