[gdal-dev] is MrSid SDK (7.0.0.2167) supported by GDAL
Collins, Benjamin collinsb at mitre.org
Tue Dec 2 09:35:12 EST 2008
Steve,
My initial tests on win32 indicate that yes, MrSID DSDK v7 does work with GDAL (1.5) with no source mods.  My test image was RGB 3-band unsigned short.
The locations of the header files has changed, though, so a windows build should now have this more simple option in the nmake.opt:
MRSID_INCLUDE = -I$(MRSID_DIR)\include
Ben
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-
> bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
> Sent: Monday, December 01, 2008 5:20 PM
> To: Gdal-Dev
> Subject: [gdal-dev] is MrSid SDK (7.0.0.2167) supported by GDAL
> Hi all,
> Quick question, Is MrSid SDK (7.0.0.2167) supported by GDAL?
> As indicated by the release notes 4. there are fixes to the JP2 readers
> and I'm wondering if that might resolve my JP2 issue since I'm
> currently
> on: MrSid SDK 6.0.7.1407
> Thanks,
>    -Steve
> Release Notes for SDK (7.0.0.2167)
> 5/28/2008
> 1. *** API CHANGE *** As described in the Porting Guide
>     section of the User Manual, breaking changes have been
>     introduced to the API, in order to address the needs of
>     more flexible workflows and pipelines in applications.
>     This will require small changes to existing code.
> 2. The LTIOFileStream class now support +2GB files. The
>     LTIOFileStream64 class has been removed.
> 3. The mix of supported platforms has been updated. See
>     platforms.txt for details.
> 4. A number of bugs have been fixed in the JP2 and NITF
>     readers and writers.
> 5. Small performance improvements have been made in many
>     areas of the code.
> 6. Member functions that are not documented (or are
>     explicitly marked as LizardTech-only) should in general
>     not be used by third-party developers.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
