[gdal-dev] autotest 1.6 errors - need help
William Kyngesburye woklist at kyngchaos.com
Wed Dec 3 00:19:57 EST 2008
On Dec 1, 2008, at 11:30 AM, Frank Warmerdam wrote:
>> - gdrivers/grass
>>  TEST: grass_2 ...
>> old =  PROJCS["UTM Zone 18, Northern Hemisphere",
>>    GEOGCS["grs80",
>>        DATUM["North_American_Datum_1983",
>>            SPHEROID["Geodetic_Reference_System_1980",
>> 6378137,298.257222101],
>>            TOWGS84[0.000,0.000,0.000]],
>>        PRIMEM["Greenwich",0],
>>        UNIT["degree",0.0174532925199433]],
>>    PROJECTION["Transverse_Mercator"],
>>    PARAMETER["latitude_of_origin",0],
>>    PARAMETER["central_meridian",-75],
>>    PARAMETER["scale_factor",0.9996],
>>    PARAMETER["false_easting",500000],
>>    PARAMETER["false_northing",0],
>>    UNIT["meter",1]]
>> new =
>> fail
>>    Projections differ
>> It seems to have completely dropped the projection.  Note that I'm
>> using a trimmed down library-only GRASS and may have missed
>> something in the dummy grass/etc/ folder.
> I didn't even know we had a grass test suite entry.  I don't
> know what is happening here.
Just tested with a full GRASS install, same problem, so it's not
missing any necessary etc/ files.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
