[GDAL-Dev]: Adding the new driver dynamically
Cherif Oueslati oueslati.cherif at gmail.com
Thu Dec 4 05:24:46 EST 2008
Hello,
I have created anew format and added it to the GDAL tree successfully using
the procedures indicated in the "GDAL Driver Implementation Tutorial".
I would like to know if there is another solution to add my driver
dynamically without following these procedures every time that I would like
to add it in another GDAL project.
Can I create a dll file to avoid the static practice indicated in the
tutorial?
Best Regards.
Cherif OUESLATI
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081204/55a7ec08/attachment.html
