[gdal-dev] File too large?
Agustin Lobo aloboaleu at gmail.com
Fri Dec 5 03:04:37 EST 2008
I have a file in envi format
(PIR_MVC_EUROM_0112_2000.bsq and PIR_MVC_EUROM_0112_2000.hdr)
 From gdalinfo I get:
 > gdalinfo PIR_MVC_EUROM_0112_2000.bsq
ERROR 4: `PIR_MVC_EUROM_0112_2000.bsq' not recognised as a supported
file format
I've also tried renaming PIR_MVC_EUROM_0112_2000.bsq
to PIR_MVC_EUROM_0112_2000
The size of the file is 6005188800 bytes, could this be the problem?
I do not have this problem with other, smaller files.
(I'm using ubuntu 8.04 and the file is on a NTFS partition)
Thanks
Dr. Agustin Lobo
Institut de Ciencies de la Terra "Jaume Almera" (CSIC)
LLuis Sole Sabaris s/n
08028 Barcelona
Spain
Tel. 34 934095410
Fax. 34 934110012
email: Agustin.Lobo at ija.csic.es
http://www.ija.csic.es/gt/obster
