[gdal-dev] gdalwarp cutting off projected image
Tue Dec 9 14:08:15 EST 2008
Scott Lewis wrote:
> Frank,
> Thanks for the help.  I tried doing this, and ended up with the same
> image (even diff found them to be the same).  Here are the various
> commands I tried.  Maybe I'm just using the -wo option wrong.
> gdalwarp -t_srs EPSG:4326 -wo SOURCE_EXTRA=1000 input.gtiff.tif
> output1.gtiff.tif
> gdalwarp -t_srs EPSG:4326 -wo "SOURCE_EXTRA=1000" input.gtiff.tif
> output2.gtiff.tif
> gdalwarp -t_srs EPSG:4326 -wo "SOURCE_EXTRA=1000 SAMPLE_GRID=YES
> SAMPLE_STEP=100" input.gtiff.tif output3.gtiff.tif
> I'll continue to play with those options, though.  gdalwarp seems to not
> act any different (IE, it takes the same amount of time to process) with
> or without the -wo option, so I'm thinking I'm just not using the option
> correctly somehow.
> Again, I appreciate your help!
Scott,
I suspect I've misconstrued what is going wrong.  If you can stage
the input file somewhere, and if it isn't too terribly huge, I would
be interested in trying it myself.  Ideally this could be filed as a
Trac ticket.
Best regards,
