[Gdal-dev] GDAL + ECW writing doesn't work on PPC Mac OSX tiger (10.4)
pbrosson pbrosson2006 at free.fr
Thu Dec 11 16:15:18 EST 2008
PowerMac G4, Mac OSX 10.4.11, tiger
powerpc-apple-darwin8.11.0
My objective is to  convert maps into ECW format (for personal use).
i have build and install  ECW SDK , and then built and install sucessfully
GDAL 1.6.0. Many thanks to the developers of GDAL and ECW.
However gdal_translate  to ECW format gives an error. (i get "Trace/BPT
trap" error  message).
To build GDAL with ECW writing, which arguments are required for configure?
Details of the build and test:
Hardware and system (PPC Mac OSX Tiger):
pmg4:~ pb$ uname -a
Darwin pmg4.local 8.11.0 Darwin Kernel Version 8.11.0: Wed Oct 10 18:26:00
PDT 2007; root:xnu-792.24.17~1/RELEASE_PPC Power Macintosh powerpc
pmg4:~ pb$
configure phase:
./configure --prefix=/usr/pkg --with-gnu-ld  \
--with-python=/usr/pkg/bin/python2.5 \
--with-sqlite3=/usr/pkg  \
--with-mysql  \
--with-pg=/usr/pkg/bin/pg_config  \
--without-grass  \
--without-libgrass  \
--with-ecw=/usr/pkg  \
--with-xerces=/usr/pkg \
--without-grib
GDAL is now configured for powerpc-apple-darwin8.11.0
 Installation directory:    /usr/pkg
 C compiler:                gcc -g -O2
 C++ compiler:              g++ -g -O2
 LIBTOOL support:           yes
LIBZ support:              external
GRASS support:             no
CFITSIO support:           no
PCRaster support:          internal
NetCDF support:            yes
LIBPNG support:            internal
LIBTIFF support:           external (BigTIFF=no)
LIBGEOTIFF support:        external
LIBJPEG support:           internal
LIBGIF support:            external
OGDI support:              no
HDF4 support:              no
HDF5 support:              no
Kakadu support:            no
JasPer support:            yes (GeoJP2=no)
ECW support:               yes
MrSID support:             no
MSG support:               no
GRIB support:              no
cURL support (wms/wcs/...):yes
PostgreSQL support:        yes
MySQL support:             yes
Ingres support:            no
Xerces-C support:          yes
NAS support:               no
Expat support:             no
ODBC support:              yes
PGeo support:              yes
OCI support:               no
GEORASTER support:         no
SDE support:               no
DODS support:              no
SQLite support:            yes
DWGdirect support          no
INFORMIX DataBlade support:no
GEOS support:              yes
Mac OS X Framework :       no
Old-gen python          no
SWIG Bindings:          no
Statically link PROJ.4:    no
enable OGR building:       yes
enable pthread support:    no
hide internal symbols:     no
GDAL version:
pmg4:~ pb$ gdal_translate --version
GDAL 1.6.0, released 2008/12/04
pmg4:~ pb$
ECW format should be supported:
pmg4:~ pb$ gdal_translate --formats | grep ECW
ECW (rw): ERMapper Compressed Wavelets
JP2ECW (rw+): ERMapper JPEG2000
pmg4:~ pb$
which input formats are supported for conversion to ECW?
runing gdal_translate from GTiff to ECW:
pmg4:~/Desktop/GDAL_conversion_folder/sample_geotiff pb$ \
gdal_translate --debug ON   -of ECW -co "DATUM=WGS84" -co "PROJ=NUTM10"
sampleGTiff.GTiff    sample.ECW
GDAL: GDALOpen(sampleGTiff.GTiff, this=0x710a4f0) succeeds as GTiff.
Input file size is 655, 655
0ECW: Writing with PROJ=NUTM10, DATUM=WGS84
Trace/BPT trap
same behaviour with Tiff or JPEG conversion to ECW
However, gdal_translate from ECW to JPEG is OK:
Input file size is 980, 1930
0...10...20...30...40...50...60...70...80...90...100 - done.
gdalinfo on the GTiff file:
gdalinfo sampleGTiff.GTiff
Driver: GTiff/GeoTIFF
Files: sampleGTiff.GTiff
Size is 655, 655
Coordinate System is:
PROJCS["WGS 84 / UTM zone 10N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.2572235630016,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-123],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","32610"]]
Origin = (563460.782789624412544,4180651.692221448291093)
Pixel Size = (14.250000000000000,-14.250000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  563460.783, 4180651.692)
Lower Left  (  563460.783, 4171317.942)
Upper Right (  572794.533, 4180651.692)
Lower Right (  572794.533, 4171317.942)
Center      (  568127.658, 4175984.817)
Band 1 Block=655x4 Type=Byte, ColorInterp=Red
Band 2 Block=655x4 Type=Byte, ColorInterp=Green
Band 3 Block=655x4 Type=Byte, ColorInterp=Blue
version of the used dependencies for the buiding of GDAL:
libtool-base-1.5.24nb6
p5-Compress-Zlib-2.015nb1
libgrass5-1.0.0
netcdf-3.6.0p1nb1
tiff-3.8.2nb4
libgeotiff-1.2.2
libungif-4.1.4nb1
jasper-1.900.1nb2
libecwj2-3.3
curl-7.18.0nb3
postgresql82-client-8.2.10
mysql  Ver 14.14 Distrib 5.1.30, for apple-darwin8.11.0 (powerpc)
xerces-c-2.7.0nb2
unixodbc-2.2.12nb1
sqlite3-3.6.4
geos-3.0.2
Is it a big/little endian problem? (PowerMacintosh CPU is big-endian)
Any help would be highly appreciated.
Thanks
philippe brosson
View this message in context: http://www.nabble.com/GDAL-%2B-ECW-writing-doesn%27t-work-on-PPC-Mac-OSX-tiger-%2810.4%29-tp20893241p20893241.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
