[gdal-dev] Force output color interpretation
Asger Sigurd Skovbo Petersen ASP at blominfo.dk
Fri Dec 12 04:32:41 EST 2008
Hi Even,
Thank you very much, it works exactly as wanted. I have looked at that option before but thought that it only applied to 3 band rasters.
Thanks again.
Best regards
Asger
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: 11. december 2008 20:23
To: gdal-dev at lists.osgeo.org
Cc: Asger Sigurd Skovbo Petersen
Subject: Re: [gdal-dev] Force output color interpretation
Asger
it appears that when translating to GeoTIFF and that the photometric interpretation creation option is not set, the GeoTIFF driver will try to make a best guess and write the interpretation as RGBA.
You can achieve what you want by specifying the photometric interpretation creation option with :
gdal_translate 2km.tif out.tif -co PHOTOMETRIC=RGB
Best regards,
Even
Le Thursday 11 December 2008 12:01:26 Asger Sigurd Skovbo Petersen, vous avez écrit :
> Hi all,
> I'm having problems with the color interpretation of the output from
> GDAL utilities. I have some 4 band (Red, Green, Blue, Near infrared)
> rasters. The fourth band is interpreted as "Undefined" by GDAL, but
> GDAL insists on marking the fourth band as ALPHA in the output. Having
> the fourth band marked as ALPHA causes a bunch of problems with other
> software, so I would really like the GDAL tools to leave it as
> "Undefined". Is this possible?
> Please find a simple example below where gdal_translate marks fourth
> band as ALPHA.
> Best regards
> Asger
> Example:
> c:\>gdalinfo --version
> GDAL 1.6.0dev, FWTools 2.2.6, released 2008/08/22
> c:\>gdalinfo 2km.tif
> Warning 1: TIFFFetchNormalTag:Incompatible type for "RichTIFFIPTC";
> tag ignored
> Driver: GTiff/GeoTIFF
> Files: 2km.tif
> Size is 10000, 10000
> Coordinate System is `'
> Origin = (580000.000000000000000,6330000.000000000000000)
> Pixel Size = (0.200000000000000,-0.200000000000000)
> Metadata:
>   TIFFTAG_SOFTWARE=Adobe Photoshop CS4 Windows
>   TIFFTAG_DATETIME=2008:12:09 17:27:10
>   TIFFTAG_XRESOLUTION=72
>   TIFFTAG_YRESOLUTION=72
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (  580000.000, 6330000.000)
> Lower Left  (  580000.000, 6328000.000)
> Upper Right (  582000.000, 6330000.000)
> Lower Right (  582000.000, 6328000.000)
> Center      (  581000.000, 6329000.000)
> Band 1 Block=10000x1 Type=Byte, ColorInterp=Red
> Band 2 Block=10000x1 Type=Byte, ColorInterp=Green
> Band 3 Block=10000x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=10000x1 Type=Byte, ColorInterp=Undefined
> c:\>gdal_translate 2km.tif out.tif
> tag ignored
> Input file size is 10000, 10000
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> c:\>gdalinfo out.tif
> Files: out.tif
> Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
>   Mask Flags: PER_DATASET ALPHA
> Band 4 Block=10000x1 Type=Byte, ColorInterp=Alpha
