[gdal-dev] GDAL/OGR 1.6.0 Released
William Kyngesburye woklist at kyngchaos.com
Sat Dec 13 14:37:21 EST 2008
My OSX GDAL 1.6 framework is now ready.  And a little late, so is
1.5.3 -- I wanted to synchronize some OSX fixes in 1.6 with 1.5, and
make sure the 2 versions work together.  More than just a new version,
here are some OSX fixes and changes:
* [1.5/1.6] HDF4 64bit OSX now works.
* [1.5/1.6] DODS OSX issues worked out.
* [1.5/1.6] ECW-JP2 support works again. It was there, it just wasn't
loading, only ECW. I also fixed a 64bit issue with ECW-JP2. This gives
OSX users a good working JP2 format driver. Note: ECW still only works
for read-only, I'll see if I can figure out write support, but don't
hold your breath.
* [1.5/1.6] Python binaries have been moved to be inside the framework
bundle. A ''gdal.pth'' file is now installed in the Python site-
packages folder to point to the framework. This lets the next change
easily work:
* [1.5/1.6] Python support on Leopard can now be used with the
python.org Python 2.5, if installed. This is in addition to the system
Python on Leopard. The ''gdal.pth'' file avoids unnecessary
duplication of the binaries.
* [1.6] The plugins folder is now versioned. For GDAL 1.6, that is ''/
Library/Application Support/GDAL/1.6/PlugIns''. GDAL 1.5 plugins will
be left in ''/Library/Application Support/GDAL/PlugIns''.
* [1.6] Internal GRASS libraries updated to GRASS 6.4.svn. (GRASS left
at 6.3 for GDAL 1.5)
Both GDAL 1.5.3 and 1.6 can be installed, but the most recent
version //installed// will be the active one for Python and developer
use.  Notes are included to switch this.  Current application builds
will still use GDAL 1.5, until I rebuild them for 1.6.
A full set of plugins for ECW and MrSID for both 1.5 and 1.6, and a
new rgdal for R 2.8, are also available.
On Dec 10, 2008, at 11:42 AM, Frank Warmerdam wrote:
> The GDAL/OGR project team is pleased to announce the release of
> GDAL/OGR 1.6.0.  This release represents 11 months of new feature
> development since the GDAL/OGR 1.5.0 release, as well as many bug
> fixes.  The release source code is available as described at:
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
