[Gdal-dev] Supporting ECW as a plugin on window,
wickley wickleyl at gmail.com
Sun Dec 14 21:21:39 EST 2008
Hello , I  have some question about supporting ECW in gdal.but I can not
solve  it. My step is following:
1.I download gdal-1.6.0 and
ImageCompressionSDKSourceCode3.3Setup_20070509.zip from ERMaper webset and
Windows Server 2003 R2 Platform SDK from microsoft website.
2. I set up Windows Server 2003 R2 Platform SDK on my computer in D:\Program
Files2.
3. I unzip the ImageCompressionSDKSourceCode3.3Setup_20070509.zip,and select
E:\libecwj2-3.3
   \Source\NCSBuildQmake\libecwj2_win32_net_shared.vcproj,using visual
studio 2005.When open the file,
   it needs translate, and it translates well with no error and just two
warnings.
4. I set visual studio 2005 project->c/c++->general ->include directory,and
add D:\Program Files2\Microsoft Platform SDK for  Windows Server 2003
R2\Include
5. I select debug,win32 ,and build libecwj2.dll successfully,and it is
included in E:\libecwj2-3.3\Source\NCSBuildQmake\Debug
6. I unzip gdal-1.6.0 to E:\gdal-1.6.0. change MSVC_VER=1400 .
7. for ECW support, I Uncomment the following and update to enable ECW
support.
    # Uncomment the following and update to enable ECW support.
    ECW_PLUGIN = YES
    ECWDIR  = 	E:\libecwj2-3.3
    ECWLIB  = 	$(ECWDIR)\Source\NCSBuildQmake\Debug\libecwj2.lib
8.   open E:\gdal-1.6.0\frmts\leveller\levellerdataset.cpp,and change { "?,
kPI / 180.0, UNITLABEL_DEGREE } to
   { "?", kPI / 180.0, UNITLABEL_DEGREE }
9. I start visual studio 2005 commandline , and change the path to
E:\gdal-1.6.0, then ,I inputs command nmake /f makefile.vc,nmake /f
makefile.vc install and nmake /f makefile.vc devinstall.
10. I copy gdal16.dll to C:\WINDOWS\system32.
11. I set tools->options->projec and solution -> vc++ direction
->includingfile->C:\warmerda\bld\include
->libraries->C:\warmerda\bld\lib
12.I build a new project,and code following:
   #include "gdal_priv.h"
   #include "stdio.h"
   #include "gdal.h"
   #pragma comment(lib, "gdal_i.lib")
   int main()
	const char *p=NULL;
	GDALDataset  *poDataset=NULL;
	GDALDriver *pDriver=NULL;
	GDALAllRegister();
	int t =GDALGetDriverCount();
	printf("%d\n",t);
	for(int k=0;k<t;k++)
		const char *pt=NULL;
		pDriver=(GDALDriver *)GDALGetDriver(k);
		pt=pDriver->GetDescription();
		printf("%s\n",pt);
result:
75
VRT
GTiff
NITF
RPFTOC
HFA
SAR_CEOS
CEOS
JAXAPALSAR
GFF
ELAS
AIG
AAIGrid
SDTS
DTED
PNG
JPEG
MEM
JDEM
GIF
ESAT
BSB
XPM
BMP
DIMAP
AirSAR
RS2
PCIDSK
PCRaster
ILWIS
SGI
SRTMHGT
Leveller
Terragen
ISIS3
ISIS2
PDS
ERS
L1B
FIT
GRIB
RMF
MSGN
RST
INGR
GSAG
GSBG
GS7BG
COSAR
TSX
COASP
PNM
DOQ1
DOQ2
ENVI
EHdr
GenBin
PAux
MFF
MFF2
FujiBAS
GSC
FAST
BT
LAN
CPG
IDA
NDF
EIR
DIPEx
LCP
RIK
USGSDEM
GXF
ADRG
BLX
there is no ECW,why?can anyone help me?
View this message in context: http://www.nabble.com/Supporting-ECW-as-a-plugin-on-window%2C-tp20997632p20997632.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
