[gdal-dev] GDAL 1.6.0 DLL Hell problem on Windows Vista?
Clay, Bruce bclay at ball.com
Tue Dec 16 18:53:05 EST 2008
Frank:
  Part of the problem seems to be in the debug version of GEOS.  I don't
know exactly where at this point.
When I use the geos_c.dll you posted ogrinfo works ok.  If I make a
release version of GEOS then it works but if I make a debug version I
get the error message.  I don't need the debug version of GEOS at this
point so I will continue with the release version.
That takes care of the C++ issues but the C# programs don't work on the
64 bit Vista system.  Everything works fine on our older systems running
XP
Thanks for your help
Bruce
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, December 16, 2008 4:41 PM
To: Clay, Bruce
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL 1.6.0 DLL Hell problem on Windows Vista?
Clay, Bruce wrote:
> Frank:
>   I am trying to run ogrinfo from the GDAL build app directory.  I did
> not have a problem with this until my computer died and I had to get a
> new one with you guessed it Vista.  It is a 64 bit system running 64
bit
> Vista so that may be part of the problem.
> Did you build with the manifest as part of the build process or just
add
> it to the runtime directory?
Bruce,
The Microsoft.VC90.CRS.manifest is part of the runtime, and I copy it
from
the runtime directory (as well as the runtime DLLs).
The GDAL16.DLL and executables also all have manifests generated
automatically
by VC, and the makefiles have an explicit step to embed the manifests
into
the DLL and executables using the "mt" command.
eg.
ogrinfo.exe:	ogrinfo.cpp $(GDALLIB) $(XTRAOBJ)
	$(CC) $(CFLAGS) $(XTRAFLAGS) ogrinfo.cpp $(XTRAOBJ) $(LIBS) \
		/link $(LINKER_FLAGS)
	if exist $@.manifest mt -manifest $@.manifest
-outputresource:$@;1
> Did you build the whole package with VS 2008 nor just the GEOS
portion?
Only GEOS was built with VS2008.  The rest was built with VS2003.
> I have run into other problems on this computer mainly with drivers.
My
> Microsoft finger print reader is not supported on 64 bit.  It makes me
> wonder just what MS is thing some times, actually most of the time.
> They keep changing things that don't help at all.
I am sure they have good reasons for the things they do, but MS
improvements often just feel like churn to me.  All this manifest stuff
has certainly been a big hassle, breaking a reasonably understandable
model of how DLLs work.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
