[gdal-dev] MrSID & December 2008 GDAL/OGR 1.6.0 Release - gdal2tiles
Klokan Petr Přidal klokan at klokan.cz
Thu Dec 18 04:45:29 EST 2008
You can try OSGeo4W package "gdal16" together with binaries for MrSID
plugin ("gdal16-mrsid" package).
Unfortunately there are now some troubles with EPSG:900913 (Spherical
Mercator a la Google Maps) so I did not recommend yet the switch from
gdal-dev to gdal16 package for OSGeo4W users.
The workaround for that right know is to run (or add into the gdal16.bat):
set GDAL_DATA=C:\OSGeo4W\apps\gdal-16\share\gdal
FrankW:
Do you plan to publish updated version of gdal16 (best with #2724 fixed ;-))?
Is there a time frame for having ECW plugin for gdal16 in OSGeo4W?
Best regards
Klokan Petr Pridal
On Wed, Dec 17, 2008 at 9:49 PM, John-Isaac Clark
<john.isaac.clark at gmail.com> wrote:
> I'd seen some previous posts about the gdal2tiles win32 command line utility
> not supporting MrSID (and other proprietary formats) until the Dec 2008 GDAL
> release. Granted this was primarily on the maptiler.org site, but I've been
> unable to dig up confirmation browsing the gdal dev sites.
> I have used the gdal2tiles built from the gdal-dev libs and works great but
> not w/MrSID as documented.
> My question is, does the Dec 2008 GDAL release support MrSID format
> conversion with gdal2tiles and more
> specifically, does the gdal2tiles command line util support MySID format
> now?
> My hope would be to have access to a gdal2tiles win32 command line util but
> I
> am also open to integrating the gdal libs into a java app I'm developing as
> well. My delivery time is very short however so I was hoping to use
> gdal2tiles
> in a win32 command line fashion on a large collection of MrSID files until I
> can specifically integrate the gdal libs.
> Thanks in advance for any assistance.
> V/r,
> jC
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
