[gdal-dev] Unexpected behavior with gdal_merge.py
Fri Dec 19 14:21:40 EST 2008
Roger André wrote:
> Just a quick question to ask for an explanation regarding something I've
> just seen in gdal_merge.py.  I have 6 tiles arranged in 2 columns, and
> which I've mosaic'd together.  I was asked to re-register the tiles in
> the 1st column by 1/2 a pixel SW.  I've done this, and in openev I can
> see that the individual tiles are shifted SW, thereby causing a gap to
> appear between the 2 columns.  All good, and what I expected.  However,
> when I mosaic the tiles together with gdal_merge.py, there is no gap,
> and it actually appears as though the tiles in the 2nd column have been
> shifted to fill the gap.  Is this to be expected?  I've read that it is
> possible to mosaic tiles together using gdalwarp, but I'm not sure how
> to do this.  If I used gdalwarp instead, would I have the expected gap?
Roger,
I don't have a precise answer to your question (lacking all sorts of
details).  I will note that gdal_merge is not savvy about subpixel
location issues.  It basically takes the top left and bottom right
corner of the input image and tries to map it to a pixel region on the
mosaic. In doing this is somewhat careless about subpixel rounding issues.
If you need precision, gdalwarp may be more appropriate.
Best regards,
