[gdal-dev] JPEG compression in TIF doesn't work
Fri Dec 19 15:51:36 EST 2008
Smith, Michael wrote:
>> I get the error message:
>> Warning 1: JPEGLib:Application transferred too many scanlines
Michael,
I have confirmed a similar problem.  Could you file a ticket in the GDAL
Trac on this topic?  The problem (apparently) only occurs when the image
height is not a multiple of the strip/block size (16 in this case).
Best regards,
