Re: [gdal-dev] HDF4 reading MISR Level 3 with incorrect dimension
Lucena, Ivan ivan.lucena at pmldnet.com
Mon Dec 29 14:04:48 EST 2008
Ok Frank,
I create the ticket [1] with links to the site [2] where the images came from.
Best regards,
Ivan
[1] http://trac.osgeo.org/gdal/ticket/2758
[2] http://eosweb.larc.nasa.gov/PRODOCS/misr/level3/level3_CGAS_small.html
>  -------Original Message-------
>  From: Frank Warmerdam <warmerdam at pobox.com>
>  Subject: Re: [gdal-dev] HDF4 reading MISR Level 3 with incorrect dimension
>  Sent: Dec 29 '08 18:08
>  Lucena, Ivan wrote:
>  > Hi there,
>  > I don't know if that is a case for a ticket or if I missed the latest discussion on HDF dimensions.
>  > I've got this HDF4 file, a MISR Level 3 product [1]:
>  > Subdatasets:
>  >   SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_CGAS_APR_2000_F15_0031.hdf":Aero
>  > solParameterAverage:Absorbing optical depth
>  >   SUBDATASET_1_DESC=[360x720x9x4] Absorbing optical depth AerosolParameterAverag
>  > e (32-bit floating-point)
>  > If I gdal_translate (with -sds) the first dataset [360x720x9x4] to GTIFF I've got a 9 bands of 720x360. That
sounds
>  > good but doesn't looks good unfortunately. The images looks like a sliced book as you would see it by the side,
a
>  > typical effect of dimension order error.
>  > Any help with that?
>  Ivan,
>  This looks like it would be worth filing a ticket, assuming you can provide
>  a pointer to the dataset in question.
>  Best regards,
>  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  light and sound - activate the windows | http://pobox.com/~warmerdam
>  and watch the world go round - Rush    | Geospatial Programmer for Rent
