[gdal-dev] Removing nodata values
Mon Dec 29 23:38:07 EST 2008
Seth Price wrote:
> How can one remove the nodata values from a GeoTIFF? I'm working with a 3
> band RGB image.
> I find many instructions on how to add the values, but none on how to
> remove them.
Seth,
Unfortunately there isn't a particularly direct way of accomplishing this.
You could do:
   gdal_translate -of VRT your.tif work.vrt
Then manually edit work.vrt and remove the line(s) with the NoDataValue
tags.   Then convert back to geotiff.
   gdal_translate work.vrt fixed_your.tif
Best regards,
