[gdal-dev] projection rejected by GDAL?
Even Rouault even.rouault at mines-paris.org
Tue Dec 30 17:08:06 EST 2008
William,
I'm a bit in your report, but my feeling is that when editing with Photoshop
you also loose the GeoTransform.
"gdal_translate -a_srs EPSG:2252 myimage.tif georefimage.tif" should work
however. I just tried it successfully with gdal-trunk.
You should also add -a_ullr ulx uly lrx lry to the gdal_translate command
line.
The "ERROR 1: Unable to compute a transformation between pixel/line..."
message should only come with gdalwarp, not gdal_translate.
Even
