[gdal-dev] GeoTIFF tag editing
sophia parafina creta.kano at gmail.com
Tue Dec 30 17:21:33 EST 2008
use tiffset, which is part of LibTIFF: http://www.remotesensing.org/libtiff/
sophia
On Tue, Dec 30, 2008 at 4:44 PM, <craig.miller at spatialminds.com> wrote:
>  Does anyone know of a command line utility that could be used to set TIFF
> tags w/o affecting any of the other image attributes such as geo tags and
> image storage method (tiled/compressed tiff)?
> I need to set attributes on several hundred thousand images and the only
> tool I've found for editing the geotiff tags so far has been a GUI tool.
> Thanks for the help,
> Craig
> Craig Miller, MS
> Owner, Geospatial Software Architect
> Spatial Minds, LLC <http://www.spatialminds.com/>
> Geospatial Software Engineering
> (206) 962-7754
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081230/c00483ea/attachment.html
