[gdal-dev] Version gdal-svn-stable-2008.01.21 with ECW support in windows
Miguel Fernandes mgfernandes at ualg.pt
Fri Feb 1 09:47:23 EST 2008
FYI
Thanks
Miguel Fernandes wrote:
> Hello Frank,
> Thanks for the support, the problem was in the dll paths.
> Best Regards,
> Miguel Fernandes
>>> Hello Frank,
>>> I've done that between every change i've made in nmake.opt
>> Miguel,
>> OK, the next things I'd check would be:
>> 1) Are there .obj files getting created in gdal/frmts/ecw (eg.
>> ecwdataset.obj)?
>> 2) Are you really really sure you are running the copy of GDAL you
>> just built?
>> Not just the .exe but also picking up the corresponding DLL?
>> I assume you are checking for available formats using the --formats
>> switch
>> to one of the commandline programs, is that right?
>> Best regards,
/Miguel Fernandes
**Projecto ERSTA*
CIMA - Centro de Investigação Marinha Ambiental
Campus de Gambelas
8005-139 Faro
Portugal
+351 289800995 ext.7574
