[gdal-dev] Converting coordinate systems(gdalwarp)
Omkaranathan omkaranathan at darshan3d.com
Sat Feb 2 04:26:52 EST 2008
I am trying to convert a geotiff file from Lat/Long to UTM coordinates
using gdalwarp.
The output data produced is gives proper coordinate system info but the
data is only a black strip.
This is the command line option I have used .
gdalwarp -t_srs "+proj=utm +zone=19 +datum=WGS84" input.tif  out.tif
Am I doing something wrong?
It'll be great if you can suggest something.
Thanks
Om
