[gdal-dev] Re: an advise about OGR const member function
Sat Feb 2 12:29:26 EST 2008
Pan Liang wrote:
> example:
>     bool func(const OGRFeature* poFeature)
>         // long OGRFeature::GetFID()
>         if( poFeature->GetFID()== _nFID )       return true;    //
> error C2662 in msvc2003.net
> but if long OGRFeature::GetFID() is declared as :
> long OGRFeature::GetFID() const, all is right.
> such const member function modify can be applied to OGRFeatureDefn*
> OGRFeature::GetDefnRef() etc.
Pan,
I'm not sure why this went to gdal-dev-owner instead of gdal-dev or me
personally.  I've taken the liberty of bringing this back to gdal-dev.
I'm generally very leery about "const correctness" changes.  The alter
the ABI and generally cause more disruption than you might imagine.  If
we are going to do a bunch of const correctness changes they must only
occur in the development version (trunk - which will be 1.6.0 eventually)
and should only affect the C++ not C ABI.  We attempt to keep the C ABI
backward compatible to the greatest extent possible.
If you feel strongly about this matter, I would suggest you prepare an
RFC listing all the const correctness changes you would like to see made
for GDAL 1.6.0, and they can be discussed as a project and if approved
moved forward.
In the meantime, you will just need to cast away the constness of the
OGRFeature for methods such as you show above.
I do think we need to be more careful about getting const correctness
right in the first place when adding new interfaces to the library.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
