[gdal-dev] gdaltindex invalid shapefile
Tue Feb 5 14:58:37 EST 2008
Oliver Ishmael wrote:
> Hello,
> I am trying to use gdaltindex to create a raster tile index for a series
> of aerial photos.
> C:\Program Files\FWTools2.0.6\bin>gdaltindex c:\2006\2006.shp c:\2006\*.ecw
> ERROR 4: Unable to open c:\2006\2006.shp or c:\2006\2006.SHP.
> Creating new index file...
> The resulting dbf of the shapefile has a ‘location’ field showing the
> location of all the ecw files. This is it. It seems to be missing the
> XMIN, YMIN, XMAX, YMAX fields and consequently ArcGIS is unable to load
> the resulting 2006.shp
> Using gdalinfo –stats I could manually enter this information but it
> would take quite a while. So I just wanted to check that I’m doing
> everything correctly?
Olly,
Does the correponding .shp file not have polygons for each record in the
.dbf file?  It is the polygons which define the footprint of each file.
Note, -stats produces information on the pixel values, not their spatial
locations.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
