[gdal-dev] Using OCI + VRT to access non spatial data
Tue Feb 5 18:55:07 EST 2008
Tamas Szekeres wrote:
> Folks,
> In some of my existing projects the client would like OGR to access
> Oracle and extract point features based on x, y columns in non spatial
> tables. Currently the only option to do such things is to set up
> VRT+ODBC for the data access that would possibly result in the
> VRT-ODBC-OCI-Oracle data access path.
> However not all of the clients can tolerate well the additional burden
> of installing an oracle-odbc driver and using additional system-wide
> settings to access their data. In addition it's sometimes not trivial
> to obtain oracle-odbc driver for a certain platform+processor
> achitecture at all (eg. linux + AMD64 in my case).
> I guess it would be reasonable to change the current OCI driver to
> provide access to tables without having Oracle Spatial to be
> installed. It would allow us to save the extra ODBC layer in the data
> access path mentioned above.
> As looking into the OCI driver to support this would be almost all
> about removing the extra checks for the spatial data types in
> OGROCISession::EstablishSession.
> How about this change?
Tamas,
It sounds like an excellent idea, though I'd ask you only apply it in
trunk (at least for now).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
