[gdal-dev] Using OCI + VRT to access non spatial data
Tamas Szekeres szekerest at gmail.com
Tue Feb 5 18:57:35 EST 2008
OK, will do so.
Best regards,
Tamas
2008/2/6, Frank Warmerdam <warmerdam at pobox.com>:
> Tamas Szekeres wrote:
> > Folks,
> > In some of my existing projects the client would like OGR to access
> > Oracle and extract point features based on x, y columns in non spatial
> > tables. Currently the only option to do such things is to set up
> > VRT+ODBC for the data access that would possibly result in the
> > VRT-ODBC-OCI-Oracle data access path.
> > However not all of the clients can tolerate well the additional burden
> > of installing an oracle-odbc driver and using additional system-wide
> > settings to access their data. In addition it's sometimes not trivial
> > to obtain oracle-odbc driver for a certain platform+processor
> > achitecture at all (eg. linux + AMD64 in my case).
> > I guess it would be reasonable to change the current OCI driver to
> > provide access to tables without having Oracle Spatial to be
> > installed. It would allow us to save the extra ODBC layer in the data
> > access path mentioned above.
> > As looking into the OCI driver to support this would be almost all
> > about removing the extra checks for the spatial data types in
> > OGROCISession::EstablishSession.
> > How about this change?
> Tamas,
> It sounds like an excellent idea, though I'd ask you only apply it in
> trunk (at least for now).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
