[gdal-dev] Unexpected value for TARGET creation option
Jean-Claude Repetto jrepetto at free.fr
Thu Feb 7 11:40:06 EST 2008
Frank Warmerdam wrote :
> The "%" is improper and should not be included.  However, I tried this and
> I see the same behavior you do. I have filed a ticket on this issue and it
> should be fixed by 1.5.1. In the meantime you can just ignore this warning.
>   http://trac.osgeo.org/gdal/ticket/2204
> The validation of creation options is new in GDAL 1.5.0.
Hello Frank,
Thanks for your answer. But the TARGET parameter is set to the default
value (75%), so the result file is 26 Mb large, instead of 6 Mb -> I
have reinstalled GDAL 1.4.2.
Regards,
Jean-Claude
