[gdal-dev] GDALwarp - Too many points (441 out of 441)
Thomas Becker thomasgeo at gmx.de
Thu Feb 7 13:22:18 EST 2008
Hello listers,
i am new to GDAL and have a problem to warp a GeoTiff.
The projection of the GeoTiff i got is shown in QGIS as
'+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs'
but the info file from the department says
ETRS89/ UTM 33 Ellipsoide GRS80.
Now i was trying to use gdalwarp with
gdalwarp -s_srs '+proj=longlat +ellps=WGS84 +datum=WGS84' -t_srs
'+proj=utm +zone=33 +ellps=GRS80' input.tif output.tif
to transform the coordinates. I was already trying it with the EPSG
codes 4326 to 25833 the error message is always the same:
ERROR 1: Too many points (441 out of 441) failed to transform,
unable to compute output bounds
I was searching in this list, found an article from 2006 but there the
utm zone seems to causing the problem.
I will add the gdalinfo output:
Driver: GTiff/GeoTIFF Size is 10000, 10000 Coordinate System is `'
Origin = (33360000.000000000000000,5972000.000000000000000) Pixel Size =
(0.200000000000000,-0.200000000000000) Metadata:
   TIFFTAG_SOFTWARE=OrthoVista
   TIFFTAG_XRESOLUTION=1
   TIFFTAG_YRESOLUTION=1
   TIFFTAG_RESOLUTIONUNIT=1 (unitless) Corner Coordinates: Upper Left
(33360000.000, 5972000.000) Lower Left (33360000.000, 5970000.000) Upper
Right (33362000.000, 5972000.000) Lower Right (33362000.000,
5970000.000) Center (33361000.000, 5971000.000) Band 1 Block=10000x1
Type=Byte, ColorInterp=Red Band 2 Block=10000x1 Type=Byte,
ColorInterp=Green Band 3 Block=10000x1 Type=Byte, ColorInterp=Blue
I hope you can help me to transform the file...
Cheers,
Thomas
