[gdal-dev] OGR shapefile problems
Even Rouault even.rouault at mines-paris.org
Sat Feb 9 18:05:11 EST 2008
I could reproduce a problem with your file on GDAL trunk and branches/1.5. It
is not MAC OS X specific.
The issue was the polygon feature whose FID = 22734, with nParts == 0.
Fixed in trunk in r13744 and in branches/1.5 in r13755
Best regards
Le Saturday 09 February 2008 23:31:57 John C. Tull, vous avez écrit :
> Hello All,
> I am running into problems with a shapefile using GDAL 1.5 binaries
> compiled by William Kyngesburye for OS X Leopard. We are trying to see
> if the problem is a GDAL 1.5 issue, or if it is something OS X related.
> The file reads properly using pre 1.5 GDAL binaries on OS X and
> Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
> 'ogrinfo -al' on the file.
> If anyone cares to take a look, I have placed the problem file online.
> You can download the landowner shapefile from
> http://homepage.mac.com/jctull/
> Thank you,
> John Tull_______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
