[gdal-dev] OGR shapefile problems
William Kyngesburye woklist at kyngchaos.com
Sat Feb 9 18:16:45 EST 2008
No, I tried it on my 10.4.11 Mini with the same crash.  Even Rouault
mentioned a fix in SVN, so I'll look into applying that to my binaries.
On Feb 9, 2008, at 5:10 PM, Dane Springmeyer wrote:
> Hi John.
> I am running GDAL 1.5.0 built from source and from Kyngesburye. Both
> are able to "ogrinfo -al" both of the nv shapefiles you posted
> without a problem.
> What errors are you getting?
> I am still on OS X 10.4.11, having not dove into the leopard world
> yet. So, perhaps the problem is 10.5 specific.
> cheers,
> Dane
> On Feb 9, 2008, at 2:31 PM, John C. Tull wrote:
>> Hello All,
>> I am running into problems with a shapefile using GDAL 1.5 binaries
>> compiled by William Kyngesburye for OS X Leopard. We are trying to
>> see if the problem is a GDAL 1.5 issue, or if it is something OS X
>> related.
>> The file reads properly using pre 1.5 GDAL binaries on OS X and
>> Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
>> 'ogrinfo -al' on the file.
>> If anyone cares to take a look, I have placed the problem file
>> online. You can download the landowner shapefile from http://homepage.mac.com/jctull/
>> Thank you,
>> John Tull_______________________________________________
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
