[gdal-dev] OGR shapefile problems
Dane Springmeyer blake at hailmail.net
Sat Feb 9 19:18:32 EST 2008
Ya, thanks John.
I Just checked out and confirmed that EVEN's commit (obviously) fixed
what you spotted.
Ogr built from svn co after 2:59 pm reads `NV_Landowner_200711.shp'
all the way through to FID 22810.
dane
On Feb 9, 2008, at 4:05 PM, John C. Tull wrote:
> Thank you Even and others for having a look, and for the quick fix.
> I'm glad to have helped uncover a small bug.
> Cheers,
> John
> On Feb 9, 2008, at 3:05 PM, Even Rouault wrote:
>> I could reproduce a problem with your file on GDAL trunk and
>> branches/1.5. It
>> is not MAC OS X specific.
>> The issue was the polygon feature whose FID = 22734, with nParts
>> == 0.
>> Fixed in trunk in r13744 and in branches/1.5 in r13755
>> Best regards
>> Le Saturday 09 February 2008 23:31:57 John C. Tull, vous avez écrit :
>>> Hello All,
>>> I am running into problems with a shapefile using GDAL 1.5 binaries
>>> compiled by William Kyngesburye for OS X Leopard. We are trying
>>> to see
>>> if the problem is a GDAL 1.5 issue, or if it is something OS X
>>> related.
>>> The file reads properly using pre 1.5 GDAL binaries on OS X and
>>> Ubuntu. I did not have a 1.5 binary on my Ubuntu vm to test. I used
>>> 'ogrinfo -al' on the file.
>>> If anyone cares to take a look, I have placed the problem file
>>> online.
>>> You can download the landowner shapefile from
>>> http://homepage.mac.com/jctull/
>>> Thank you,
>>> John Tull_______________________________________________
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
