[gdal-dev] gdalwarp rather than gdal_translate
Mon Feb 11 23:36:46 EST 2008
Diana Esch-Mosher wrote:
> I have a NITF file that I would like to resample using the more
> sophisticated interpolation techniques of gdalwarp (-rcs). I do not want
> the file to change in way other than size, I do not want to
> transform/reproject/warp etc. When I specified gdalwarp -rcs -ts x y -of
> GTiff it transformed the file in a North up. How do I specify to not do
> anything other than resample?
Diana,
Currently gdalwarp does not support producing output files with georeferencing
based on a GCPs.  You can write a file with a non-north up geotransform but
only by pre-creating the file replicating the input geotransform which is not
really practical from the commandline.
 > Is it possible to specify -of NITF? I
> tried this using 114 and got errors. Do I need 115 for NITF?
gdalwarp should support creating NITF files.
When you refer to 114 and 115 are you meaning GDAL/OGR 1.1.4 and 1.1.5?
Those are ancient!
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
