[gdal-dev] GDAL and NUTM17 NAD83 datasets.
Daniele Romagnoli dany.geotools at gmail.com
Tue Feb 12 09:28:16 EST 2008
Hi again Frank.
My fault :(
I performed some tests on java bindings for Gdal 1.5.0 and I moved GDAL_DATA
from gdal-1.4.4/data to gdal-1.5.0/data.
I badly thought that the GDAL_DATA content was the same in the 2 versions
while the 1.4.4 looks for a ecw_cs.dat while the 1.5.0 looks for a
ecw_cs.wkt.
My fault... sorry.
Regards,
Daniele
On Feb 12, 2008 3:16 PM, Daniele Romagnoli <dany.geotools at gmail.com> wrote:
> Frank,
> thanks for your reply.
> I have already properly set the GDAL_DATA var :(. (And the cited file
> ecw_cs.wkt is present there)
> Here's why I investigated for a Proj4 responsability.
> Which type of permissions problems do you think should be involved? (I'm
> using Windows Vista and GDAL_DATA links to a simple folder C:\work\gdal...
> As an instance I know that Vista may introduce some problems in several
> circumstances when working with C:\ProgramFiles... Moreover I have disabled
> User Account Control some months ago...)
> Thanks a lot. I will narrow my search for the cause of the problem.
> Regards,
> Daniele
> On Feb 12, 2008 3:04 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> > Daniele Romagnoli wrote:
> > > Hi list,
> > > During my tests, I noticed that when using my build of gdal (1.4.4 on
> > > windows xp) I can't get a Coordinate System for some specific
> > Datasets.
> > > As an instance I used gdalinfo from fwtools 2.0.4 on a ECW file and I
> > > obtained this Coordinate System (partial copy and paste).
> > > Using "my" gdalinfo I obtain the classic empty string.
> > > I guess this issue could be Proj4 related (although I'm not really
> > sure
> > > about this).
> > > For this reason I surfed the mailing list and I downloaded the proj4
> > > library, I set the PROJ_LIB linking the NAD folder and I added the DLL
> > > in the path. (GDAL_DATA has been already set in the past)
> > > Anyway, the result is the same: empty coordinate system returned. As a
> > > parallel experiment, I also tried statically linking the library with
> > > the same result.
> > > Is there some additional operations which fwtools based gdalinfo
> > performs?
> > > I'm surely wrong somewhere :)
> > > Any help would be greatly appreciated.
> > Daniele,
> > GDAL needs to find the ecw_cs.wkt dictionary file to lookup ECW
> > coordinate
> > system names.  This is normally found via the GDAL_DATA pointer.  You
> > mention
> > you have this set, but I am suspecting it is set improperly or perhaps
> > there
> > is some related sort of error (permissions?).
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> > and watch the world go round - Rush    | President OSGeo,
> > http://osgeo.org
> Eng. Daniele Romagnoli
> Software Engineer
> GeoSolutions S.A.S.
> Via Carignoni 51
> 55041 Camaiore (LU)
> Italy
> phone: +39 0584983027
> fax:     +39 0584983027
> mob:   +39 328 0559267
> http://www.geo-solutions.it
Software Engineer
GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
Italy
fax:     +39 0584983027
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080212/e37a2452/attachment.html
