[gdal-dev] ngpython and GetSubDataSets()?
Tue Feb 12 16:42:04 EST 2008
Jose Luis Gomez Dans wrote:
> Hi, I've just compiled gdal 1.5.0 on a Linux RHEL5 X86_64 machine. I need to
> use HDF files extensively, so I've been trying to test whether the new
> compiled GDAL works. In python, I noticed that I no longer get all the
> methods I used to get.
> AttributeError: GetSubDatasets
> I solved the problem by getting rid of the
> /usr/lib64/python2.4/site-packages/GDAL-1.5.0-py2.4-linux-x86_64.egg/
> directory, which takes me back to the "oldgen" bindings. My question is
> whether all the methods from the oldgen bindings have already made it to the
> ng bindings, or whether there will be other changes that will make my
> software incompatible when the ng switch goes live, and for which I will
> need to modify my code.
Jose,
I see this was implemented in the old gen bindings as a convenience
function like this:
     def GetSubDatasets(self):
         sd_list = []
         sd = self.GetMetadata('SUBDATASETS')
         if sd is None:
             return sd_list
         i = 1
         while sd.has_key('SUBDATASET_'+str(i)+'_NAME'):
             sd_list.append( ( sd['SUBDATASET_'+str(i)+'_NAME'],
                               sd['SUBDATASET_'+str(i)+'_DESC'] ) )
             i = i + 1
         return sd_list
You could essentially do the same thing in your own code.
Howard, how would you feel about incorporating this as syntactic
sugar in the NG bindings?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
