[gdal-dev] gdalwarp rather than gdal_translate
Tue Feb 12 17:47:30 EST 2008
Diana Esch-Mosher wrote:
> I looked at gdalwarp and I see where it checks to see if the destination
> file exists, if so then it reads the TargetSRS from that dataset. So I
> should pre-create to the target size that I am requesting in gdalwarp? I
> have no problem in python  pre-creating the file, copying the metadata,
> geotransform, and projection data ... anything else I should copy? Then
> I just call gdalwarp as gdalwarp -rcs -ts x y -of  NITF (or any other
> -of  I want).
Diana,
Right, except of course you don't specify parameters used to create the
file (like -of or -ts).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
