[gdal-dev] Linking MinGW app builds against VC++ built GDAL
Ari Jolma ari.jolma at tkk.fi
Wed Feb 13 01:51:40 EST 2008
Frank Warmerdam kirjoitti:
> I'm not sure what the pexports and dlltool stuff is for.  I have
> found I can link MingGW applications directly against gdal_i.lib
> without any special stuff.
I use them to make the import lib. I can't make perl Makefile.PL accept
gdal_i.lib (which is annoying!) but if I edit it by hand into the
Makefiles everything works - almost, I get some errors from the
self-tests but they are also related to the version mismatches.
> Is it possible you are trying to build GDAL "trunk" bindings?
Yes, I was using the trunk version of wrappers.
However, I wonder how useful this is. Perl is packaged for cygwin and
probably I should use that (instead of the MinGW perl I've compiled
myself) for the OSGeo4W perl bindings for GDAL.
Ari
Prof. Ari Jolma
Geoinformatiikka / Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
