[gdal-dev] question about using gdal_rasterize
Limei Ran lran at unc.edu
Wed Feb 13 10:48:28 EST 2008
Hi:
I need to rasterize a polygon shapefile with a modified map extent.  I
did not see setting x and y min and max for the shapefile when using
gdal_rasterize.  I can use gdal_rasterize first and then gdalwarp to set
the extent .  Are there any direct way to do it with some codings?
Thanks
Limei
