[gdal-dev] OGR Spatial reference shifting
Wed Feb 20 19:10:20 EST 2008
Christiaan Janssen wrote:
> Does anyone else notice issues using the coordinate conversion in OGR
> Spatial Reference. When I try to convert from a state plane system in US
> feet to WGS84 Lat/Lon everything is shifted about 1.75 degrees to the
> east. Specifically I'm converting Nad83 State Plane 101 (Alabama East)
> US Feet to WGS84 Lat/Lon meters. Maybe this is a Proj.4 issue but I'm
> not sure, any help would be greatly appreciated.
Christiaan,
There are many things that can go wrong.  :-(
Can you be more specific about exactly what you are doing, how you are
specifying the input and output coordinate system, what results you get
(ie. a sample point in and out) and why you believe the result is wrong?
1.75 degrees is a big error, so it clearly isn't a datum shifting error.
It could be a linear units issue (feet vs. meters) for either the
false easting/northings or the actual values being transformed.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
