[gdal-dev] OGR Spatial reference shifting
Christiaan Janssen cjanssen at iavo-rs.com
Wed Feb 20 19:37:50 EST 2008
As it turns out the issue was a false easting due to not supplying the unit type in the setStatePlane function. After using the setStatePlane function I called the setLinearUnits which apparently didn't have the same effect (understandly). Now... another issue, I'm using the OGRCoordinateConversion function to convert from NAD83 StatePlane 3200 meters to NAD83 StatePlane 3200 feet and everything is correct except the Z value is not being converted. Any clue on this one. Thanks all for the help.
Christiaan
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, February 20, 2008 7:10 PM
To: Christiaan Janssen
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] OGR Spatial reference shifting
Christiaan Janssen wrote:
> Does anyone else notice issues using the coordinate conversion in OGR
> Spatial Reference. When I try to convert from a state plane system in
> US feet to WGS84 Lat/Lon everything is shifted about 1.75 degrees to
> the east. Specifically I'm converting Nad83 State Plane 101 (Alabama
> East) US Feet to WGS84 Lat/Lon meters. Maybe this is a Proj.4 issue
> but I'm not sure, any help would be greatly appreciated.
Christiaan,
There are many things that can go wrong.  :-(
Can you be more specific about exactly what you are doing, how you are specifying the input and output coordinate system, what results you get (ie. a sample point in and out) and why you believe the result is wrong?
1.75 degrees is a big error, so it clearly isn't a datum shifting error.
It could be a linear units issue (feet vs. meters) for either the false easting/northings or the actual values being transformed.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
