[Gdal-dev] Problem in Coordinate Transformation
bargi bhagwat.maimt at gmail.com
Thu Feb 21 01:57:34 EST 2008
Hi to all,
I am working on a project in which I have to project shapefiles on our
Application.
I am facing problem in transforming coordinate from one system to another
I googled a lot and found some code and try to run it.........but Its not
working properly..............
The code is as follow:
[code]
    if ( !__GOOGRFeatureSourceDriversRegistered ) {
        OGRRegisterAll();
        __GOOGRFeatureSourceDriversRegistered = true;
     OGRDataSource *ogrDataSource = OGRSFDriverRegistrar::Open( qPrintable(
file ));
     if ( !ogrDataSource ) {
         return false;
const int nLayers = ogrDataSource->GetLayerCount();
     OGRLayer *layer = ogrDataSource->GetLayer( 0 );
     m_displayName   = layer->GetLayerDefn()->GetName();
     m_path          = file;
     m_driverName    = ogrDataSource->GetDriver()->GetName();
     for ( int i = 0; i < nLayers; ++i ) {
         layer = ogrDataSource->GetLayer( i );
         OGRSpatialReference*    pSourceSRS = layer->GetSpatialRef();
         OGRSpatialReference*    pTargetSRS = pSourceSRS->Clone();
         pTargetSRS->SetProjCS("TM");
         pTargetSRS->SetTM(0,0,1,0,0);
         OGRGeometry*  poGeometry;
         double x,y;
        OGRCoordinateTransformation* poCT =
OGRCreateCoordinateTransformation(pSourceSRS,pTargetSRS);
          layer->ResetReading();
         OGRFeature *ogrFeature = 0;
         while ( (ogrFeature = layer->GetNextFeature()) ) {
               poGeometry = ogrFeature->GetGeometryRef();
                if (poGeometry !=NULL)  {
             if (wkbFlatten(poGeometry->getGeometryType()) == wkbLineString)
                 OGRPoint *poPoint = (OGRPoint *) poGeometry;
                 x = poPoint->getX();
                 y = poPoint->getY();
               if (poCT!= NULL || !poCT->Transform(1,&x,&y)) {
                   poPoint->setX(x);    //Set coordinate
                   poPoint->setY(y);
                   qDebug()<< poCT;
                   printf( "(\n%f,%f) ->
(%f,%f)\n",poPoint->getX(),poPoint->getY(),x, y );
                   GOFeature *feature = new GOFeature( ogrFeature );
                   features.push_back( feature );
[/code]
But it is not changing the coordinate............
The output is as follow when printf statement run......
(0.000000,0.000000) -> (0.000000,0.000000)
I am not able to understand where is the problem ?????
I this forum I found a post in which there was given suggestion for
Transformation  which is as follow:
[code]
 o Create a new layer for the output.
 o Make sure you pass the altered OGRSpatialReference to the
    CreateLayer() call.
 o You might as well just call transform() on the geometry
    instead of extracting the point and transforming that.
[/code]
When I try to use CreateLayer("MyFile",pTargetSRS,wkbunknow,null) function
,It gives error that ABC.shp file open in readonly ,MyFile cannot be
created........
The following line
Is for adding features to a list from which we can extract features to
draw................
Also please tell me how can I stored changed coordinate of features and
retrieve them later..........
Any queries are welcome.........
Please help me to resolve the problem and please give steps of
implementation.....
Thanks
View this message in context: http://www.nabble.com/Problem-in-Coordinate-Transformation-tp15605836p15605836.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
