[gdal-dev] FWTools: gdatindex running slow...
Fri Feb 22 15:12:40 EST 2008
estrada.adam at gmail.com wrote:
> All,
>     I have been using FWTools versions 2.0.4 and 2.1.0 and gdaltindex
> is taking considerably more time than in previous versions.  I recall
> it not working at all with version 2.0.3!  Earlier versions worked
> well and much faster than the current version.  Has anyone else
> noticed this performance difference?
I believe this relates to:
If you set the GDAL_LIST_SIBLING_FILES environment variable to FALSE
you may find it speeds up significantly.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
