R: [gdal-dev] GDAL & Python
marco.pasetti at alice.it marco.pasetti at alice.it
Tue Feb 26 11:50:56 EST 2008
Hi Frank,
I'm building GDAL right now --with-python option enabled; I thought the same as you suggested... but now I'm trying build GDAL without python installed, because the last option enables python bindings, and, I think, this feature would not require python installed; furthermore, configure tells that the old python support is deprecated and suggests (as I understood) to enable python bindings instead.
thanks
Marco
Da: Frank Warmerdam [mailto:warmerdam at pobox.com]
Inviato: mar 26/02/2008 17.00
A: marco.pasetti at alice.it
Cc: gdal-dev at lists.osgeo.org
Oggetto: Re: [gdal-dev] GDAL & Python
marco.pasetti at alice.it wrote:
> Hi,
> I'm building GDAL 1.5.0 on windows with MinGW.
> Do I need Python to enable its support in GDAL? (I have Python 2.5.1
> installed, but not in a "standard" msys directory)
> configure option is just "--with-python", while configure help doesn't
> tell about an option like --with-python-inc/lib or something like that!?
Marco,
I believe that the key is to have your installed python in the path, and then
the python setup.py script for GDAL queries it to find appropriate information.
I can't promise that msys/mingw builds with python support will be easy
though.  I'm under the impression it might be tricky though I haven't done
it myself.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org <http://osgeo.org/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080226/363234c8/attachment.html
