[gdal-dev] GDAL & Python
marco.pasetti at alice.it marco.pasetti at alice.it
Tue Feb 26 12:27:36 EST 2008
relaunched make with, before, export PATH="/c/devtools/python:$PATH"
Now I have the following error:
error: Python was built with Visual Studio 2003;
extensions must be built with a compiler than can generate compatible binaries.
Visual Studio 2003 was not found on this system. If you have Cygwin installed,
you can try compiling with MingW32, by passing "-c mingw32" to setup.py.
must I directly hack makefile? (hope not!)
Thanks
Marco
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080226/01201e1d/attachment.html
