[gdal-dev] grib/grib2 capability
Bas Retsios retsios at itc.nl
Tue Feb 26 13:01:24 EST 2008
Hi!
In nmake.opt, find the lines:
      # Enable if you have the grib directory in \frmts
      # GRIB_SETTING=yes
uncomment the 2nd line, and rebuild GDAL.
Cheers,
Bas.
Leigh Childress wrote:
> Hi all
> I did an svn checkout of the trunk this morning and used grib/grib2
> sample data with the command line utility gdalinfo and I continually
> got the unsupported file format error.
> Are there some changes that need to be made to the makefile or the
> nmake.opt or some other file to enable this grib/grib2 functionality?
> Thanks
> LeRetha Childress
>_______________________________________________
>gdal-dev mailing list
>gdal-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080226/039de5f9/attachment.html
