[gdal-dev] Motion: Commiter Status for Moratto
Lucena, Ivan ivan.lucena at pmldnet.com
Wed Feb 27 22:10:09 EST 2008
Thank you Tamas,
It sounds like a good plan to me.
Stefano (Moratto) started the Delphi interface completely outside of the
GDAL trunk in a FWTools distribution. I organized his code in the folder
structure (.\swig\delphi, .\swig\include\delphi\*.i, .\swig\makefile.vc)
but he is not using the interfaces on .\swig\interface\*.i yet.
What do you think Stefano (or should we call you Moratto)? Can we comply
with those requirements?
Best regards,
Ivan
Tamas Szekeres wrote:
> Ivan,
> I'm +1 to the motion to add Stefano as a commiter.
> With regards to the addition it would be required to restructure the
> implementation can be found in
> http://svn.osgeo.org/gdal/sandbox/ilucena/swig/ a bit before adding it
> to the trunk.
> Any of the SWIG bindings should be built upon a common ground just
> like for the other languages we currently have. I think one of the
> most important goals around here is to ensure the proper convergence
> between the interfaces that the various languages can provide.
> Currently all of the SWIG bindings are derived from the interface
> files in the /swig/include directory of the gdal project tree. These
> files contain the desired wrappers (shadow classes) of the GDAL C API.
> The generated interfaces will finally link against the gdal.dll and
> doesn't create a separate dll for hosting the gdal/ogr related code.
> Would it be realizable to follow the policy mentioned above?
> Best regards,
> Tamas
> 2008/2/27, Lucena, Ivan <ivan.lucena at pmldnet.com>:
>> Moratto has been using GDAL in the development of Delphi application for
>>  quite some time now, but as his work has evolved he felt the need to use
>>  SWIG to generate a wrapper. The problem is that there no official Delphi
>>  module in SWIG, so he developed it himself.
>>  Moratto would need the Commiter Status to migrate the wrapper from my
>>  sandbox to the trunk to continue his work in the development of the GDAL
>>  Delphi wrapper.
>>  Moratto has reviewed RFC 3 on commiter responsibilities, and has agreed
>>  to them.
>>  Best regards,
>>  Ivan Lucena
>>  _______________________________________________
>>  gdal-dev mailing list
>>  gdal-dev at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
